MATLAB to control the serial port voltage
absoluthish
Computer
Apr 23, 2007
Hi
i m trying to control(ON/OFF) a LED using the serial port on the MATLAB .. up till now all i found that the MATLAB only sends a string or binary to the port
can anyone help me on how to control the voltage on the serial port pins ?
thanks in advance
Hisham
As a computer professional, you should already know that RS-232 does not allow for voltage adjustment
TTFN
FAQ731-376
As a Computer Professional i already know that pin4 and pin7 in the RS232 change polarity during the transmission and reception ..
my problem is that i need to control these pins
thanks for your generous help :)
Hisham
It changes polarity because it SWITCHES between the FIXED positive supply and the FIXED negative supply. There is no programming of the voltages.
TTFN
FAQ731-376
If you are trying to do a binary switch, the parallel port would be your best choice. The matlab data acquisition toolbox has support for parallel port operations.
A quick web search turned up several other options. Here is one that describes one of the harder techniques:
At your own risk, you may be able to find someone who has already done this and posted the DLL.
CV
