tnteng
- Oct 24, 2002
- 58
I am trying to select an appropriate W-beam and channel cap for a runway beam that is to support an under running bridge crane. The channel cap is to be on top of the W-beam. I am using the AISC ASD code and I am having problems with what value to use for "bf" in formula F1-2. Would "bf" be the width of the channel flange or the width of the W-beam flange? Am I correct in assuming that "Af" in that formula would be the sum of the area of one flange of the W-beam and the area of the web of the channel.
Also in section B.5.1, on the check for compact or non-compact section, b/t is compared to 65/sqrt(Fy). What value of "b" & "t" should be used in this case with the composite section?
Thanks in advance for any help with this problem.
Tony Billeaud
Mechanical Engineer
Tony Billeaud
Mechanical Engineer
