rocksolid
Industrial
- Nov 1, 2001
- 17
Is there a simple formual for figuring out a basic
flat pattern for a helical screw flight segment?
Example: 9" diameter screw x 4" core x 1/4" thick flight, 18" pitch, 90 degree segment.
I dont mind being just close on the flat pattern. I can
afford to trial a couple of pieces prior to making the
final part. I just need a good starting point "formula" to work from
Thank-you.
Thank-you.
