Need help using exportfig
NS4U
Hi, I am trying to use exportfig but for some reason it's not working as well as I had hoped. My code to output a figure is:
set(gcf, 'Units', 'Inches')
exportfig(gcf,[filename '-Impedance Channel 1 to Channel ' num2str(inst-1)], 'format', 'eps','width', 6,'height',6, 'color','rgb', 'lockAxes', 0, 'bounds','tight', 'FontMode', 'fixed');
I know eps is by far the best quality graphic. However, when I import these figures into word 2007 the graphic is (for lack of a better term) messed up. The plot displayed in word is slightly different than the one shown when output from matlab. However, if I just straight convert the eps figure to a PDF it comes out perfectly... is this something unique to word 07?
Also, I change the format to jpeg and for some reason the graphic size is always like 50" x 50"... it doesn't seem to matter what width/height I set
I want to use high quality images, however my documents are prepared in word, so I will need something that will work with word.
Any thoughts? Am I using exportfig correctly?
