aerobordo
New member
- May 15, 2007
- 2
I have an equation z=2x+y. My problem is that x and y are taken from two different experimental setups with different acquisition rates that cannot be changed. Therefore, x is a 2975X1 double and y is a 10000X1 double. I have tried to filter the 10000X1 down to a 2975X1, but I lose critical data points in the process. Is there a way to add points to the 2975X1 to make it 10000X1? Or does anyone have additional suggestions?
Thanks for the help,
Chris
Chris
