How to simulate a flash separator?
Chemical
Feb 19, 2002
Hi, I am trying to simulate a Flash Separator using Hysys Software, but I just could find a simple separator in it.
The inlet is natural gas and I have its properties and composition.
I will appreciate your help.
Thanks :->
K.S.
Hysys does the thermodynamic in the streams (and all the time, you dont need to "start" the simulation). Atatch a drum to a stream with 2 phases and the vapour goes out the top and the liq. out the botrom (a 3 phase is also available).
If your steam only have 1 phase then all of the steam will go through the top or bottom stream attached to the drum.
Anyway: Try study the manual and tutorials.
Best Regards
Morten
Morten, thanks a lot . I read Hysys tutorial, but I could not find an exact information.
Any way, you are right I am going to study the manual deeply.
K.S.
HI 1080847,
A flash separator for a liquid at it's bubble point,can be worked by putting a PRV (pressure reduction valve) up stream of the separator,at which point you will have Two phase going into the separator..
Email me the composition and I will send you the results..
Ofcourse,it will also work if you use a sinle stage column..
Try it..and good luck
wayil@hotmail.com
