cdi12
- Jul 1, 2006
- 38
Catalogs for adhesive or mechanical anchor bolts usually give allowable and ultimate loads and their ratio is around 1:4. However ratio between nominal loads (using allowable stress design) and factored loads (using strength design) is less than 1:2. This means allowable stress design gives you anchor bolts about 2 times smaller than strength design. Am I missing something?
IV
IV
