oscaril
- Oct 12, 2005
- 9
Should the ends of conduits end with sealing fittings in non-hazardous locations when conduits themselves pass class 1, division 1 area? We have conduits under the slab in an aircraft hangar that is class 1, division 1 area according to NEC but conduits ends are in office and electrical rooms.
What type of conduits should be used in the slab, steel or PVC? Conduits are concrete incased at depth of less than 600mm.
Can sealing fittings be concealed in walls or they should always be accessible to pump out gases?
Thanks beforehand!
Thanks beforehand!
