Does anyone know of tutorials for non uniform pressure in Cosmos. If I had a simple cylinder and loaded the inside walls with non uniform pressure. Say zero at one end and X at the other, how is this done? I tried a quick example but it always went the wrong way, even if I put -Y in or reversed the direction. I always put the highest load at the "wrong" end. I also didn't know what the max & min pressures were. Can this be "seen"
Go easy on me I'm not into FEA
