When blending two different crudes, is there a calculation that may be used to determine the cloud point of a blend based on the cloud points of the original crudes?
Alternatively, is there a relationship between the density and viscosity of a crude blend and its cloud point? e.g. something like the Viscosity Gravity Constant calculation....
The object is to determine the cloud point of the crude as it is being blended.
We have available the volume ratios of the component crudes and the density and viscosity (at process and reference temperatures) for the blend and can have them also for the component streams.
JMW
JMW
