Minimum Vertical Curve Length Requried for 15 mph road.
tavo75
4
Does someone know or point me in the right direction on what would be the minimum length needed for a vertical curve where i have an algebraic difference of 5.8%? The road has a 15mph limit for a residential area on a military base in Hawaii (Oahu). The road also T's into a road with a 25mph limit. The algegraic difference does not occur at the intersections but does occur about 30 from the intersection.
I wouldn't go any less than a K-value of 9. With a difference of 5.8%, it looks like you need a 55 to 60 foot curve. I would tie the curve to the cross slope of the other road.
You left out a unit. 30 ft or 30 m?
"...students of traffic are beginning to realize the false economy of mechanically controlled traffic, and hand work by trained officers will again prevail." - Wm. Phelps Eno, ca. 1928
"I'm searching for the questions, so my answers will make sense." - Stephen Brust
I checked the AASHTO publication "Geometric Design of Very Low-Volume Local Roads (ADT<400)".
For a 15 mph desighn speed, k=2.0
The length of the vertical curve would 35' for A=.058.
Sorry, that K value was in feet. That came from the Indiana DOT Design Manual K value table for "comfort criteria" which is typically the lowest value they will allow without a design exception.
Is it a sag or crest curve? If it is a crest, you'll need to make sure moving trucks won't get hung up. Especially since it is a military base, where people are constantly being reassigned, and moving in or out.
