Basic question on symmetry
Wernstrom
I have a basic question on using symmetry. I have cut my model in half in order to take advantage of symmetry and the point load is on the plane of symmetry. Should I use half of the actual load as the input or will Cosmos take care of that?
I have been told that I should halve the load, but I'm not entirely convinced. Is this something that is constant throughout FEA programs or does it depend on which one you are using?
That is consistent across FEA. Half the model half the load. Pressure on the other hand would be unchanged. If you are unconvinced do a simple case where a hand calculation can be used for validation like beam theory. Hope this helps.
Robert Stupplebeen
"symmetry" condition in FE (whichever the FE program) is an appropriate set of displacement boundary conditions. This does not impact loads nor this is a "switch" making the program "aware" of anything. So you will definitely have to halve the load. On the same concept, if you were dealing with cyclic-symmetry with 10 repetitions per circumference, for example, you would have to load your cyclic-sector with 1/10 of the total load.
