caluna
- Nov 23, 2004
- 86
Question about settings for our thermal relief PRVs around valves in tank farms. Nornmally we have the PRvs set at 25 psi in the piping and 75 psi at the valve directly off the tank (our tanks are not enormous -max size 460,000 l). The thermal bypass lines go around the valve in all cases-(ie not directly back into tank). We have had problems (sample barels filling too fast) further on in the lines past the PRVs and I think our settings are the problem. In worst case we have about 15 psi headon system (due to height of tanks) with pump not running-pump head about 25 psi (includes hydraulic head)-so sounds as though 25 psi is not enough..Should we be seeting the PRV at 10 % more? We are using Swagelock PRVs which have allen key adjustment an nominal seeting stamped on side but vatiable range. The service staff adjust "as required" but as they do not have proper test set its hard to know what pressure seeting we are getting til the PRV is in the line..
Thanks for any thoughts!
