How to deal with problem when a ramp to ramp flow exists???
sashi34u
In a particular question related to the weaving, merge and diverge analysis it is given that a ramp to ramp flow of 200 veh/h exists.
It is a 3 lane highway section with free way flow of 3200 veh/h. the section has 2 ramps. The first one is an on ramp with a ramp flow of 600 veh/h. The second ramp is an off ramp with a flow of 75o veh/h.
The problem suggests that an auxillary lane is brought in between the on and off ramps, thus converting it into a weaving section.
Now my doubt is
1) Should I consider inner weaving volumes(Vw1, Vw2) as
Vw1=750veh/h and Vw2=600Veh/h
(or)
2) Should i consider the inner volumes as
Vw1=(750-200)=550 Veh/h
Vw2=(600-200)=400 Veh/h
I had deducted 200 from the volumes as it is ramp to ramp flow.
Can anyone clear my doubt?
Your second calculation appears to be correct.
The ramp to ramp flow is 200 non-weaving vehicles.
The on-ramp to freeway weaving volume is the on-ramp volume minus the non-weaving traffic (600-200=400)
The freeway to ramp weave is the off-ramp volume minus the non-weaving traffic from the upstream ramp (750-200=550)
Vw1 is the higher weaving volume
Hi teeman,
Yes what you said is correct. tyhe second part is right.
I got to know about it from my professor.
Thanks for responding.
