mrkoko
- Aug 3, 2007
- 40
Ok, I'm am brand new to COSMOS works but have been using solidworks for about 5 years. I have designed a Hinge and now I would like to use COSMOS on the assembly of the hinge to help calculate how much weight it can hold. I tried goes through COSMOS putting bolt restraints on the hinge mounting holes, pin restraint on the hinge pin, I applied a shrink fit condition to one side of the hinge to pin connection, I applied a hinge restraint on the bores of each side of the hinge, I applied material properties to my parts and I applied a load on the end of the free hinge plate, but I can't get COSMOS to run with out errors. Is there something I am doing REALLY wrong ? Or does anyone have any suggestions for me ? Thanks!!!
