Joint Constraints
marciot
BR
How can i constrained two line of joints selecting all line? I can do this selecting the first joint on the line one, with the first joint on the line two, than do the same with the second joint, the third, etc, creating various constraints. How can I make this without having to select joint by joint, only selecting the line one and constrained all joints with the line two(they have to be in order, first joint of one line with the first joint of the other line)? I’m using the equal constraint.
