pipes traction force
Jihed
4
Hi everybody,
Does anyone know how to calculate the traction force required for the traction machine onboard a pipelay barge based on the weight lenght and dimeter of the pipes and how to calculate the ground traction. I heard about special specific gravity but I dont have clear idea on how to start the calculations.
thank you
Assume the pipe is a catenary curve and calculate the tension forces necessary to hold the profile you want.
"We can't solve problems by using the same kind of thinking we used when we created them." -Albert Einstein
