dieselpet07
Chemical
- Jan 17, 2008
- 21
In petroleum refinery particulary in Coker plant most of the cooling water heat exchangers especially debutanizer overhead cooling water condenser , wet gas compressor interstage cooler are getting fouled severly including leakage also found with in 4-5 months of operation eventhough cooling water quality like pH,TDS & other necessary parameters are being maintained but still fouling/leakage observed.The detail analysis of foulant/depositions (inside the tubes)at the time of shut down / maintenance of exchanger has also been carried out and it was found mostly Fe2O3 -60% & others are PO4-3 & almost ~97 % of Fe2o3 in the fouling depostis analysis which was deposited on outside surface of the tubes.The exchangers MOC is C.S.The one of the mystry that could not able to identified properly - the frequent fouling/leakage problem of most of C.W.HEs are started after comissioning & taking in line of new Cooling tower.(Pl. note that the operating & quality parameters of C.W.is well with in specs in comparision to other C.T.s in the refinery).
Now the question is what could be the probable & root cause of these severe fouling/leakage of HEs ?
Thanks in advance to all of you..
