Vinny7
- Jan 27, 2003
- 54
If a portal is clad in blockwork to eaves (no sheeting rails) can it be assumed the blockwall (215MM thk.) between the flanges (305X165 Universal Beam) be considered as providing restraint to the column compression flange at the bottom of the rafter haunch. IF not has anyone any suggestions? Note, the eaves tie will probably be at higher level to suit the roof and wall bracing.
