rtpnd
- Jan 19, 2007
- 9
I'm putting a proposal together for a structural peer review, and am not quite sure how to set my fees. If I was the structural engineer of record, I would likely charge about 3/4% of the total construction cost.
But since I'm not the structural engineer of record, I know my time requirements will be down significantly, as I do not have to produce drawings, do not take on the overall project liability, and will run only a percentage of the calculations I normally would (i.e. check the design of 25-50% of beams and columns, etc.). I'm basically checking for code compliance and constructability issues.
Does anyone have experience in determining fees for a structural peer review?
Thanks!
Thanks!
