DaveDexter
- Apr 22, 2002
- 1
Hi
I'm attempting to reverse engineer a PIC device and I have the operation of the PIC down very well - it sends an ID, a specific time after power up.
The device is connected to a limited current source and two parralel 0603 capacitors are used to provide a voltage for the PIC. I have the voltage waveform of the charging parralel capacitors and I want to calculate their values. Does anyone know how I can do this accurately?
Surrounding the PIC is a SOT-23 device which I believe to be a Digital Transistor connected to the charged capacitors, the output and the pin that drives the logic on the PIC. Why doesn't the PIC pin drive the output directly and what benefit does the device have? Is it likely to be something different to a Digital Transistor (eg a MOSFET or diode of some kind) and how can I find out.
I have the voltage waveforms and 1 pin is high during operation (base?) whilst the output (emitter?) follows the pulse seen at the input (collector?). Why is this implemented?
The markings on the SOT-23 device are N4 46 (N4 is written perpendicular to the device) but I have done a search for what it may be and I haven't been too successful. Does anyone know a place which may help me narrow the device down.
Many thanks in advance for your help - it's much appreciated.
Dex
Dex
