ROSE EXTRACTION 1
AJALI
Chemical
Apr 27, 2002
DID ANY ONE HELP ME IN ANY LITERATURE ON THE PLANT DESIGN OF ROSE EXTRACTION WITH HEXANE .THIS INCLUDE EXTRACTION CYCLE AND HEXANE STRIPPING.
THANKS ALOT
If this is KBR's ROSE process, I'm afraid my knowledge is limited to the C3/C4 solvents with some limited information on the pentane solvent. I hadn't heard they were using hexane as well. If that information would help you, let me know.
Same as said by TD2K, the KBR ROSE unit is with C2/ C3. Havent heard of Rose unit with Hexane (C6). I will be intersted in theis topic if you find anything on the C6 Solvent let me know.
Thanks.
Thanx
As far as I'm aware of, the ROSE process doesn't involve supercritical extraction as the name would indicate but supercritical solvent recovery and extract fractionation.
That's true, the solvent is below the critical temperature for the extraction of the paraffinic oil. It's then taken above the critical temperature to cause the oil's solubility in the solvent to essentially go to zero allowing the two to be separated in a simple 2 phase separator.
