Nexim
- Feb 7, 2008
- 22
I'm having a problem with a sketch I'm doing in SW 2007. Please see the image attached. Basically, I have a spline, and a vertical centerline, and I want to mirror the spline about the centerline. However, I want it so that at the intersection of the spline and centerline (1st spline point) the tangent is horizontal. (Such that the original and mirrorred splines smoothly connect).
You can see where I have selected the spline point, and tried to change the tangent angle. The only way it is letting me change the actual angle is by manually rotating the spline by dragging one of the handles with the mouse. When I try to type a number into the box, as soon as I click back out of the box (expecting to see the change), the number just goes back to what it was again.
Being a perfectionist, this is driving me mad. I need to get the angle at 180', and 179.78...' isn't good enough.
Does anyone know why it's not letting me input the angle?
