I'm rebuilding a 'fat' ultralight, and discovered a dent in one of the wing struts. Replacement tubing is expensive (to me) to ship at 9' in length, and it's a shame to waste an otherwise 'good' part.
I looked at AC43.13 and only found help on splicing tubing on longerons/webs.
My thought is, since the cross sectional area has not changed (it's dented, not split in two), I wouldn't need the 24,000 lbs of shear capacity the AC43.13 splice would seem to provide...assuming my math is right...if I sleeved the dent as though it were a split. I could then use easy-to-find 1100F soft rivets rather than 2117-T's that I cannot seem to find.
The point of the repair is to transmit the wing strut stresses across the dent - I'm open to suggestions on how to do this, economically.
Can anybody help a chemical engineer stay safe and financially solvent?
