Recycling blowing agent (having solvent) from Nutsche filters. 1
luciom
Chemical
May 29, 2001
18
In blowing the filter cake in our Nutsche filter with nitrogen significant quantities of solvent (Isopropanol)
are lost. Is there an established technology whereby both the gas & solvent can be recycled ?
If your pressure is < 15 PSI, you could theoretically use a roots type positive displacement blower to recirculate the N2 throught the filter. The knockout pot between the filter and blower would need to be a vacuum rated pressure vessel. You may also neet a heat exchanger on the blower discharge to remove the heat of compression, as these type of blowers are roughly 50-60% efficient. If you cool the blower discharge enough (chiller?), you may need another pressure vessel for the condensed and reclaimed solvent.
A major impediment to success would likely be diatomaceous earth (filter aid) carryover into the blower. Due to its abrasive action, the blower life would be short if carryover is significant.
It is very possible that my company can help you. It just happens that we are installing a piece of equipment that incorporates a nutsche filter and solvent recovery along with a fluidbed dryer. We would love to discuss your application in a more secure manner. Please contact Russell Husfeld or Alan Nix at 1-800-228-3217.
Also, visit our website:
Solvent recovery must be faily common for this type of application.
Best Regards
Morten
