Will two 1/8 thick flat washers 2-1/2" OD x 17/32" ID stacked one on top of the other and used in an assembly perform closer to one 3/16" thick washer or closer to one 1/4" thick washer in ablility to resist cupping deformation during bolt tensioning? My application is mounting a coach built body (1800#) on a truck chassis in 12 places. Fastener is a 1/2"-13 x 2-1/2" Lg fully threaded Gr 5 flange head bolt with Gr 5 flange lock nut. At each body mount location the body structure consists of double thickness of 10ga sheetmetal. The flat washers would be stacked one on top of the other with the bolt passing through the two washers and the body assembly, then through a 1/2" thick rubber pad between the body assembly and the 1/4" truck chassis upper C shape flange, a 1/4" thick rubber pad on the opposite side of the chassis upper C flange and then a 1/4" thick mild steel plate with the locknut on the bottom. The mount is very compliant, bolt is torqued to 55 lb-ft preload. Under live testing two 1/8" thick washers yielded and cupped very slightly (.020" from flat). The question is: would this result influence you to go toward the 1/4" thick single washer or toward the 3/16" thick single washer? Putting it another way, did the stacked 1/8" washers perform equal to, less than, or slightly better than a 3/16" washer will,... or more closely to how a single 1/4" thick washer will? Consider that no more testing is allowed. Should I recommend the single 3/16" or the single 1/4" thick washer to replace the two 1/8 washers?
