Remove all hard Page Breaks
infinityvortex
Automotive
Aug 27, 2008
6
Is it possible to remoev all hard page Breaks (the ones that you can insert) of a mathCAD file? I have some Collapsed "Areas" there as well, so is there a way to avoid affecting them but removing all inserted page breaks?
Hello! I'm the new guy.
Simple answer is unfortunately no.
one method is to change the view mode to Show regions, then change the zoom setting to 25%. you should now be able to select more easily as the page breaks show all the way across but regular regions are just on the left.
Philip
Didn't you ask this question in the Mathcad Collaboratory?
The answer was that you should probably use your own page breaks so that you have better control.
TTFN
FAQ731-376
