Problem with matrix 1
ANNIS
Materials
Jan 3, 2009
11
Hi I'm trying to sum a matrix and I get an error.
I have a document where its done and im trying to do the same.
The error can be viewed here:
(or in the attatchment)
Im using mcd 14, and the document Is most lilekly created in mcd. 13. Its proberly just a setting I need to ajust. Please help :)?
I should mention that I have used "subscript" when I wrote "tk" in the sum..
You are right " Its proberly just a setting I need to ajust."
What is the index of the first element in your vector?
Cheers
Greg Locock
SIG:please see FAQ731-376 for tips on how to make the best use of Eng-Tips.
I think what Greg is trying to say is that the default origin is 0. With k=1..n, you are summing to an invalid index n. Either change ORIGIN to 1 or k=0..n-1.
Next time, posting the actual sheet would be more useful than a picture of the sheet, particularly since the actual sheet would give you the error message that would have made it obvious what the problem is: "The array index is invalid for this array"
If this is not the actual error message, it should be, but that means that you've used the literal subscript operator "." instead of "[" for the index subscript.
TTFN
FAQ731-376
Thx to jghrist I got it.
