find the element of an array
pagheca
31
I'm looking for the simplest way to find the index of the element of a vector that is closer to a given value.
Suppose the vector is f[i:=i^2 and the value V:40 .
The solution is i=6 as 6^2=36. How to find that i value? Do there is any function doing that? Do you know any trick using the programming?
See attachment for an attempt to solve it (not working.
regards and thanks in advance
You can do this without programming. Using the variables in your sheet:
Error:= vectorize abs(f-v.LO)
Index:= match(min(Error),Error)
Vectorize is a function on the matrix toolbar.
Peter
thanks very much, Peter. A very smart solution.
However, the result is a vector itself. How to convert it to a number?
Thanks again!
got it: I have to specify the index, of course... I was confused by the fact it was a one element vector!
Thanks again.
