Hi there,
I have converted all of Appendix 13 (Non-Circular Vessels) into a spreadsheet.
I am having a problem ironing out the errors in the more complex Sketch 6. Is anyone an expert on this?
I am prepared to give all my Appendix 13 spreadsheets if someone wants to work with me on this. Is there a Spreadsheet forum that anyone knows of?
In Particular, ThetaM is supposed to measure the angle on the long-side radiused bend where the bending stress is the greatest. It comes up with angles over 70°. However the bend in my example is only 45° in total. I get similar results for other examples. How can a stress be at 70° when the bend is only 45°. Below is the equation which makes no sense. It is close to the beginning of the calcs so I can't see an error.
Theta1 = arctan(-K5*S1/(2R²-R*S1-L3*t1))
where
K5 = L2 + L21
S1 = 2*R + t1 (This dimension makes no sense.)
Also betaM = arctan(CM/(L3-E*Theta1)) is strange
Surely it should be betaM = arctan(CM/(L3-EM))
But ASME has no errors? Right?
I have attached a drawing of the example if it helps.
I have used CodeCalc to check it. It gives a similar crazy angle but I found that CodeCalc has a few errors in its App13 calcs so can't trust it to much.
Any help would be appreiciated.
where
K5 = L2 + L21
