Xeros
Materials
- Dec 5, 2006
- 54
Somebody said that using B7 (without protection) bolt for external SS flange (no thermal insulation) shall be inhibited because this is a dissimmilar metal contact and galvanic corrosion could occur (because rain water could be electrolyte).
Therefore isolation kit or coating shall be applied for preventing galvanic corrosion.
However, B7 bolting has been used for SS Pressure Vessel and there is no problem until now.
How about member's opinion?
In addtion, what type of coating should be used, if I applied coating for bolting?
