grouchley
Mining
- Apr 4, 2009
- 2
what is the best filler to weld astm a743 ca15?
preheating or no preheating?
post welding heat treatment?
This is a large valve ball about 80cm in diameter and the weld will be about 10 kg.
Is it better to weld in stages to control the heat buildup?
