aesoton
Marine/Ocean
- Sep 25, 2002
- 42
Hello all,
I am looking into how to model the material properties of various materials in FEA. I need to be able to use BH curves in this process. If I wanted to use the Preisach model for hysteresis, how can I get the parameters alpha, beta and gamma? Can they be calculated from a material BH curve or is it simply a case of curve fitting?
Also, if I cannot get hold of a BH curve to fit to, what would you suggest as a method when you have the remanence, max permeability, saturation etc. in a table form?
