What materials allow a magnetic flux at very high (1000 C) temps ?
MeTwo
10
What materials allow a flux to flow at temperatures in the region of 1000C ?
Which of these materials would survive in an air atmosphere at that temperature ?
None.
You'll need to locate a magnet external to that environment.
Did you have an application in mind or is this just a thought experiment?
I know about needing to locate an external magnet.
Its an application. I want to actuate a valve inside a high temperature environment.
Anyone ?
Does steel allow a magnetic flux above the Currie temp ?
You already got your answer:it's no.
Above the Curie temperature ferromagnetic materials become simply paramagnetic, not very different from vacuum. By the way steel would be unable to do almost anything at that temperature.
prex
: Online engineering calculations
: Magnetic brakes for fun rides
: Air bearing pads
Sorry, I missed the "none" part of your reply.
Do any ceramic materials possess magnetic properties at elevated temperatures ?
What is the highest temperature that steel is permeable and what kind of steel ?
Look up a list of curie temperatures.
I don't recall anything above about 450C.
Plymouth Tube
But, isn't the OP essentially asking whether something like steel can remain paramagnetic, and hence, still be usuable as a solenoid plunger, for example?
TTFN
FAQ731-376
