Automated Stellite deposition
baski67
12
Dear all
Looking for automated equipment for internal deposition of stellite21 and stellite6 on carbon steel and stainless steel castings of taper profile
Please provide dimensions of your tube - ID, OD, wall thickness and length of the tube.
What thickness do you plan to deposit? Is it for wear/erosion resistance?
If you do a search for HIP Bonding on the internet you should come up with something.
Glyn
automated TIG welding may be used to deposit stellite. I have worked with automated welding machines to achieve this for hard-facing turbine blades. the dimensions of your product will dictate the accessibility.
our web-site shows our larger automated machines.
