I'm working with a group migrating from Ideas to NX5 (5.0.6.3 specifically). I've been presented with the existing work flow and drawings and I'm trying to re-create them in NX. The attached PDF shows a current drawing. Basically showing the flat pattern fully dimensioned with Bend CL's and OML's. These OML's are sketched in the viewport then hidden after dimensions added in Ideas.
My thoughts on this were to have NX show the outer mold lines that could be dimensioned in drafting. This would eliminate the sketching in the views. My issue is that I cannot seem to get the outer mold lines to show. In Pref > Sheetmetal - I have the Outer Mold lines turned on (also in the drafting view). <see attached .prt files>
A note that states how I got my flat pattern with either the K-factor (or Neutral Factor Value) or the calculated bend deduction should be enough for the vendor to build the part accurately based on the flat pattern & formed part.
The other question, of course, is how useful is the flat pattern to the sheet metal vendor? It shows the vendor the thought process and how you got to the end formed part but in the end, all I want is the formed part to be accurate.
Thanks in advance for your input,
Matt
Matt
