bbook1
Industrial
- Aug 17, 2009
- 14
I have a spur gear that I need to calculate "Span" (Base Tangent Length). I found this website " but I am unsure about "Backlash" in this tool. The gear specifies an Agma Backlash Class A, but when I enter this into the tool it gives me a number that is much smaller than the physical measurement of the part over three teeth. I am having a Swiss company make this part, they use Span rather than measurement over wires. Can anyone help me to calculate this correctly?
Agma = 10
Number of teeth = 20
DP = 96
PA = 20 deg
OD = 0.2271/0.2230
PD = 0.2083
Face Width = 0.050
Tooth Form = INVOLUTE
Backlash Class = A
I would like to understand this calculation rather than have someone just give me the numbers (although, I would like to have the numbers).
Agma = 10
DP = 96
PA = 20 deg
OD = 0.2271/0.2230
PD = 0.2083
Face Width = 0.050
Backlash Class = A
