Form A, Form C contacts 3
slavag
2,035
0
36
IL
Dear ANSI EE.
Could you please give short explanation, what is a different between Form A and Form C contact.
What need use for the trip and close commands,
Additional, what is a From A with current control contact.
Sorry for Q, Im never work with ANSI relay.
Thanks in advance.
Best Regards.
Slava
Form A is single normally open contact.
Form C is one normally open contact and one normally closed contact with a "common" terminal between them. Form C contact assembly has three terminals. NO-Comm-NC.
They can be part of any type of a relay or auxiliary switch.
Normally open contacts are commonly used to trip and closing commands,but really it depends on the control circuit.
Rafiq Bulsara
Form A - Contact open in the rest/deenergized/shelf state of the device.
Form B - Contact closed in the rest/deenergized/shelf state of the device.
Form C - Two contacts, one A and one B, with a single common.
Code:
   |            |           __|__
   A            B              C
