AllAngles
- Oct 31, 2009
- 29
Hi guys - I'm brand new to the forum as a member, but have been lurking for months as I transition from the world of corporate Information Technology to working for myself at my own Mechanical Design company. So, first off, thanks for all the great information here!
My business is basically a mechanical systems design and prototyping service and is very much in the startup phase. I use Inventor and Showcase to design and model parts, then use my connections with shops to quote and, if needed, produce prototypes. I'm not a PE, nor do I intend to become one (at this point), so this is a DESIGN business.
Already in my projects thus far, it has come up that in the process of designing a system or part for a clients patented concept, I've come up with something that can stand on its own as a patentable idea. My only client (so far) happens to be a good friend who encourages me to patent whatever I come up with on my own; zero issues of ownership for the IP. But, certainly as I start dealing with other companies, I will need to have a more formal agreement in place regarding any IP generated while working on their job.
So, is there a standard out there regarding this type of situation? Do most agreements typically give the client ownership of any IP related to their project, or to the designer, or is it a case-by-case basis? Just looking to get a feel as I begin to write up my business documents (with some help from an attorney friend).
Thanks for any input!
Mikah B.
Mikah B.
