dcceecy
- Oct 15, 2008
- 112
I try to find the wind load on a pole with ASCE-7.
I assume the pole is flexible structures so I need to calculate the Gust Effect Factor G. so I have to know the natural frequency of the pole.
In the code, the fundamental period of structures is calculated as Ct h^x in seismic section. but if I use this formula, the pole is rigid structure (f > 1 HZ).
I am wondering if I used the right equation or should I just calcualte the frequency using flexural rigidty (EI) of a cantilever beam (the pole).
any suggestions are welcome.
