  • Congratulations waross on being selected by the Tek-Tips community for having the most helpful posts in the forums last week. Way to Go!
motor cool time constant
tem1234
192
0
0
CA
Hi guys,
i'm trying to set the correct cool time constant motor running and motor stopped on a GE multilin 469.
On the motor data sheet, the info is:
Thermal copper time constant (short time altern.) : 3.6 min.
Thermal time constant (long time load altern.): 20 min.
Thermal time constant for cooling down (standstill): 140 min.
As i see it, the cool time constant stopped is 140 min, but i'm not sure about the running. What's "long time load altern." standing for?
We often set the running constant 1/2 of the stopped constant where info is missing.
Any idea?
Customers often ask for cooling time constant for our machine, where MULTILIN protection is used. The time constant should be defined as removing the heat to a level of 1/e (i.e. 36.8%)…or 63.2% total heat removed.
The temperature drops at an exponential rate. The time constant is based on temperature (rise) dropping to 1/e of the total rise. The time for drop in pre-defined level of temperature rise may be reverse calculated. With elapsed time, the temperature changes per the following:
Tt = Th * e(-t/(tau))
where, Th = total temperature rise
t = elapsed time
tau = cooling time constant
Tt = remaining temperature rise
Following typical cooling time constants, regardless of the motor size, can be used.
Running cooling time constant is 45 minutes (10 minutes for 20% drop in temperature rise).
Stopped cooling time constant is 100 minutes (22 minutes for 20% drop in temperature rise).
