par060
- Feb 28, 2001
- 146
I have an inspector who is checking some A325 bolts in slip critical connections that I designed. The bolts are supposed to be tensioned to 19 kips. The inspector is useing a torque wrench to check the bolts. What is the required value that he should be looking for(ft-lbs)?...I found a method of calcing the torque but it requires a "Torque coeeficient"...(K)..that I cannot find. My bolts are A325 5/8" diameter...galvinized.
Also I'm not sure that his method is correct in checking the torque. The bolts have been installed for about 2 months and from what I read some relaxation of the connection and elongation in the bolt will effect the tension...if anyone has any comments or input I would like to hear some....thanks
