What is male/female socket weld?
ryanhu
Petroleum
CA
Hi everyone
Is that the same with male/female Threaded?
So the male socketweld is buttweld,Is that right?
Socket welded connections are a type of welded connection where there is a male component that slides into a female component and then a fillet weld is made between the shoulder of the female component and shank of the male component.
Please refer to ASME B16.11 for typical dimensions and details.
A male socket welding end does not normally have any reduction in outside diameter. The outside diameter is constant and a fillet weld is used. The official dimensions for socket welded components would be specified in ASME B16.11.
Would like to back up rneill's contribution, and add that you're looking at a valve that has a "normal" SW end (female) with the other being male.
Heather Smith
My interests: Alloy valves, duplex valves, super duplex valves, 6Moly valves, inconel valves, incoloy valves, alloy 20 valves and titanium valves.
