bigmakattak
- Mar 28, 2010
- 5
I want to move a post in the basement to make a clear span of 17 feet for the main floor beam. It is (3) 2 x 12's now with a 12' span. I have calculated to the point of figuring the plate to be 5/16" on each side but will use 3/8" x 10". I have calculated max shear of 5.9K, max moment of 26 ft-k. with a load of 675 plf. Properties: I(transformed) 1943 in fourth, A (transformed) 184 in squared, and S (transformed) of 345 in cubed.
I want to bolt through the wood to connect both plates and the wood and have them act composite.
How can I determine the spacing and number of 5/8 inch bolts? Plan to stagger them vertically on the 10" plate.
Also any tips for checking bearing on the wood wall columns made up of 2 x 4's would be helpful. Can transformed area be used in the bearing calculation?
I am a rusty old Civil Eng. not structural.
Bigmakattak
