  • Congratulations Toost on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Material characteristic of Fittings (Elbows, Reducers, Tees) 1
KOSUPPLY
3
Would there be any difference in the material characteristics of WPHY 42 and WPB with a minimum of 42,000 yield. What is the effect if the WPB with 42K yield is used in lieu of the WPHY 42?
I am aware that WPHY is generally associated with higher yields like WPHY 60 but this time we are only asked for 42k yield and I want to know if the WPB (42k min yield) would generally be accepted as a substitute.
ASTM A234 WPB yield stress is 32 ksi
ASTM A234 WPC yield stress is 40 ksi
WPHY is an MSS SP-75 designation for higher yield strength fittings 42 = 42 ksi, 60 = 60 ksi, etc.
Because of the different yield strengths associated with each one, none could be considered equal.
"The problem isn't finding the solution, its trying to get to the real question." BigInch
Thanks BigInch,
My understanding is that the A234 WPB has a minimum yield of 32ksi as you stated. However I have material test reports showing this A234 WPB with yields from 43100 - 49400 ksi (They exceed the minimum yield). This would fall within the parameters of the MSS SP-75 WPHY 42 for yield. Other than yield which this WPB material meets, are there any other differences that I should consider or should know about if we decide to substitute this material?
I have attached the material test report for the A234 WPB which shows the yields.
 http://files.engineering.com/getfile.aspx?folder=8604892e-e4ca-41a5-aef1-1bc73fb1c187&file=TM028615.TIF
Yield strengths vary from batch to batch and it is quite possible that the fitting has yields higher than that required, BUT SP-75 still has many other requirements that 234 WBP dosn't address; too many to address here. ASTM A234 is basically one material specification for low strength fittings. SP-75 concerns high strength fittings. Its not only about yield stress. You really need to read both specs. don't you think.
Yes you are absolutely right I should read both specs, but I am having trouble finding them, thats why I came here. Thanks a bunch for you input, you have been really helpful.
