yoel280206
- Feb 9, 2010
- 11
Dear all,
I am trying to design an Organic Rankine Cycle (ORC) for Power and Cooling.
The heat source is solar heat.
I use pure ammonia as working fluid.
Starting from ORC for power, it comprises turbine, condenser, pump and evaporator (boiler).
I use water as coolant in condenser.
Therefore the outlet temperature of ammonia from turbine is limitted by water temperature in condenser.
The inlet water temperature in condenser is 15 Celcius.
So the outlet temperature of turbine should be > 15 Celcius and in vapor phase.
For instance, the outlet temperature of ammonia from turbin is 28 Celcius with pressure is 11 bar.
So it will be in vapor phase.
Then the ammonia vapor is condensed by condenser to be liquid then pumped to evaporator as a cycle.
So, i am going to use this ORC also for cooling.
If i use turbine with discharge pressure of 2 bar, the outlet temperature of ammonia from turbine will be <15 Celcius, for example 5 Celcius.
So i can use it for cooling, then the ammonia temperature will be 12 Celcius.
At this point, the ammonia is in vapor phase.
However there is a problem.
How can i change this ammonia vapor with condition of 2 bar and 12 Celcius to be liquid phase?
So the pump can pump the liquid to evaporator as a cycle.
How about the condenser, it might be useless now?
Any other ways to use ORC with pure refrigerant as power and also for cooling?
Thanks so much..
Thanks so much..
