When applying the BMS595 sealant to the electrical faying surface, do you also cover the electrical bond area.
My interpetation of Boeing Spec BAC5117-6 Cat 2 is that you apply the sealant to the entire faying surface of one part. I'm dealing with an aluminum assy and there is a bracket to be installed with a small "bare" area on the bracket and the mating part.
