Foundation Fieldbus Connector
rodneysab
Petroleum
Jan 16, 2009
5
Foundation fieldbus Connectors have 4 pins but only 2 are necessary. What are the other 2 for? Our contractor claims connectos with only 2 pins are suitable, where can I base his allegations on?
I believe that Foundation Fieldbus H1 is a two wire interface. The two wires carry both 24 VDC for device power and also the communications signal.
I was not aware that there is/was a "standard" connector for FF H1.
Actually I mean not the H1 but the spur segment.
FF H1 is the fieldbus that uses 24VDC with Manchester encoding for the data. They have another, newer fieldbus that is ethernet based.
So your "spur" lines are also H1.
Ok in this case only two pins are really necessary. But why are there connectors with 4 pins? So far I haven´t got any reasonable explanation.
Thanks anyway.
You are probably talking about the M12 type connectors. These are a standard, general purpose connector that is reasonably water proof. Used quite frequently in Europe. For some reason seems to have become widely used with FF H1 and also Profibus-PA. Both of those fieldbusses use the same electrical interface. So one answer is legacy and history.
Note that all three Foundation Fieldbus connectors, whether M12 or 7/8" 4 pole connectors, use only one pair of signal wires and a shield wire:
ABB 7/8" pinout
Turck 7/8" pinout
Turck M12 pinout
