Bronco425
- Apr 9, 2010
- 8
I am currently working with a 3 wire Y connection and am debating adding a wire to ground the neutral point. I am doing failure analysis that can result in "explosions" due to arcing from welded contacts. My understanding is that the 4th line would act as a safety for when the phases become unbalanced. Would this also reduce the "exploding" effect when there is a failure?
