We are laying a buried 72' diameter CS grade x65 with 15.48 mm wall thickness with Cement Mortar Lining for water supply.
Contractor proposes to pull elastic bends to follow the horizontal alignment. I am not familiar with B31.4. Does the standard permit the use f elastic bends, is there any limits on the stresses. Presumably the residual elastic stress will need to be taken into account in the overall stress analysis and there will be a reduction in the allowable pressure rating.
